Brake Bleeding
Danzigman
Galveston, TX
I was wondering the same thing as I would like to add stainless lines. I was thinking of getting speed bleeders. Has anyone used these?
anguyen325
the way i've always done it is to have someone in the car. u tighten the bleed valve and tell the person in the car to pump the brakes with the engine off about 6-10 times then hold. While they hold the brake pedal down, loosen the bleed valve. The brake fluid is going to shoot out so watch ur face lol. Be sure to start at the caliper farthest away from the master cylinder. Just work ur way towards the closest repeating the process 2-3 times with each caliper.
brice715
