Timmy
bingo!
see, that wasn't so hard.
bingo!
ppfftt....run it for a couple hours to let glue settle, cool...and power up. I never break them in for 20 hours.
The best way would be to replace the speakers first. The BOSE amp redirects the proper frequency range to the corresponding speakers, i.e. high frequencies to the tweets, midrange to the mid drivers, etc. In other words, a built in x-over. Unless you add a passive x-over to the factory components, you'll end up damaging the tweets, even at low to moderate volume.
You can add an in-line cap to the tweets and run the mid-driver and tweeter parallel. At the amp there are seperate wires for the front mids, tweeters, rear speakers, and of course the sub.
Front left mid: tan+, grey-
Front right mid: lt green+, dark green-
Rear left: brown+, yellow-
Rear right: dark blue+, light blue-
I don't remember the tweeter wire colors off-hand, but this will get you started in case you decide to do it.
So..... when I get my components like I had posted about earlier, Do I need to splice the mid to exisiting wiring and the tweet also to the factory wiring in the pillar...... Or do I utilize the crossover that comes with the components????
