Big MPG drop....
U2SLOW4ME
Dallas, Tx,
So, I bought my 09 PPV last summer and was averaging 400 miles per tank. A few months ago I put new tires on it (same size, same air pressure, different brand) and I dropped to 350 miles per tank. It has been very consistant both before and after the tires. Then a few weeks ago I installed a K&N to hopefully pick a few miles back up and its even worse!!! Now I'm getting about 315 miles per tank. Same driving conditions to and from work, no special trips or rompings. I even went with a synthetic blend on the last oil change. I have about 80,000 miles on it. Any ideas????
AZSCTACO
Phoenix, AZ
Have you cleaned the throttle body or MAS (Mass Air Sensor) before?? I'd start there.
U
U2SLOW4ME
Dallas, Tx,
No. I will soon just to mark it off the list. The tires have puzzled me more than anything. It was a noticable drop the first day after driving it.
TheFuzz
Idiot Police
Spurbury, VT
Tires can vary substantially in weight, even between tires of the same size and manufacturer that have different load ratings (ie, p-metric vs D or E load rating...more plies = heavier).
What tires did you have on it before and what did you have put on?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
use of ac is also a big factor. Stop and go traffic. Tires may be the same but could have some wieght as to your old tires with less tread on it or rolling resistance
jonfo
If I remember right the stock 20" wheels weigh ~40lbs with tires I took off at 35k miles (2/3 tread worn off). When I went with new 24" Ziniks and Cooper Zeon AT 305s they weighed ~90lbs each!
U
U2SLOW4ME
Dallas, Tx,
It had the Good-Year Eagles on it when I bought it but I put the Nexen Roadian HP's on it because they were half the price. The way it seems, If I had stuck with Good-Year I would eventually save $$ through gas.
dizhai
