Bench testing EVAP vent solenoid for leak P0442
treehan77
TYF Fiend
Crestview, FL
Am i correct in thinking that when i apply 12 volts to the plug on the evap vent valve solenoid (by the canister) i shouldn't be able to blow through it? I can't tell any difference when powered or not, can blow through it either way. It does click when power is applied. But it also rattles if i turn it upside down. It is only like 6 months old, can't remember, but i think i tested it before i installed it and i couldn't blow through it when power is applied. Thanks again, this small leak is really testing me.
Kraig
It probably only requires 5 volts. Is it AC Delco or some parts store brand?
treehan77
treehan77
TYF Fiend
Crestview, FL
Ac delco Just want to know, shouldnt it be closed - meaning I shouldn’t be able to blow or suck through it when power is applied
treehan77
treehan77
TYF Fiend
Crestview, FL
Well after another new ac delco part arrived, I tested it too. Cannot blow through it with power applied. Other will be getting refunded from amazon by way of ac delco a 2 year warranty.
zkonrad001
