belltech 2/3 drop on 26s have problem somebody help!!!
2001tahoefuentes
Passaic,NJ
So today i got bored and i said im goin to put my 26s on my hoe after i did the belltech 2/3 drop kit and then i take around the block and wen i come back i see my front passenger tire looks like its been slashed and i check and find out a piece of metal behind the fender is doin this can someone help me solve this problem
Knobz
Santa Cruz, CA
Take hammer and flatten it or cut it off.. Your gonna have to do some trimming with 26's. mostly in the back.. A shop did it for me though so not sure exactly what they cut but they cut out a few spots.
SC88
Chicago Burbs
You will need to trim the plastic in the back as well the front. The only metal that rubbed my wheel was from the drivers fender behind the plastic to the right if you are looking at the wheel.
I ultimately removed my lowering kit because I could not get it to stop rubbing with the 305s and I did not want to cut or trim anymore off the truck.
You can run 295/25/26 and that will end all your rubbing issues but a good tire in that size will set you back $240ea
I'm getting use to riding back high, its not so bad lol
vsaravia
