Belltech 15+ coilovers kit
NORCAL SS
SUV SUSPENSION GURU
ANOTHER NORCAL SS First. I've been talking to belltech about making coilovers for 07 up gm suvs and Adam at belltech listened and came thru for me. Tested on my Escalade and works out great!!!
i can set it all up with you for magride or non magride trucks
on my website
https://tbssowners.com/store/index.php?act=viewProd&productId=646
Fifty
This will successfully bypass the mrc codes on the 15+
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Yes mrc bypass for front will be a option
Fifty
I’d be in for a mrc by pass coilovers lift for front and rear! With remote reservoirs...
Nice set of kings please... 2-3 inch lift...
35’s...on 18’s is all I need!
16blkltz
What about for 15+ Tahoes with Autoride suspension? What is the advantage (if any) of coilovers vs autoride? I have a 2/4 drop (Mcgaughys spindles in front and belltech 5305 springs with Mcgauphys shock brackets in rear).
tbordenet
I'm ready for coilovers and a mrc bypass. Keep us posted!
Fifty
What size shaft are they using? Is the fluid volume going to be considerably bigger?
The weight of these vehicles and damper travel is so detrimental heat wise that the factory Tuning mrc is extremely temp dependent and from what I’m told is as important in the algorithm and graphs as frequency.
That means to me that they overheat easy. Meaning the replacements need to have a lot of fluid and a reservoir for cooling let alone extra storage and nitro for pressure and anti bubble ;) !!!
sclade66
Tony Norcal SS. How is the mrc delete kit coming along? We are ready
tbordenet
Hey Tony, Do you have any news on the coilovers or a MRC delete?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Update.... these things ride 10x better than autoride.
Currently on 26s and 10non rebound setting and 12 in compression and rides so good.
Rears are due to mevin 2 weeks. I akso am working on a part number for onky the fronts.
Durobans
