Backup camera stays on
Wfd0311
I have a 2018 Tahoe and my backup camera will not shut off. My reverse lights will also remain on while the truck is in drive. The normal display screen comes on when the key is turned to accessory mode but once the ignition is turned the backup camera comes on. I took it to the dealer last week and they charged me a $150 diagnostic fee and called me the next day and said they needed more time to figure the problem out and would be an added $150 per hour until they can figure it out. I decided to decline the service especially not knowing how much it was going to cost just in diagnostic fees. Anyone know what the issue could be? Thanks
Gregorytedd
Had the same thing happen in my 2018, any luck with figuring it out? Local dealer can’t get me in until the 21st
can pretty much bet money it's either a shift cable adjustment or shift interlock solenoid
you could start with a visual inspection of the shift linkage (under the truck) and see if it looks worn or has a piece of the sleeve cracked or missing
it's not uncommon for them literally fall off as these trucks age
mrbala
Were you able to figure this out? Having the same issue. Thanks
Did you resolve the issue?
Same problem here with my 2020 yukon xl.
Problem Started during current cold snap. Wonder if it is related.
TexasTaz
