Back windows Defroster not working
Chevyrider619
Virginia Beach
Well,i was trying to clear the backmindows all that worked were mirrors so the defroster on the back is not working..Can any1 tell me where to start at to check for trobleshoots???:Plugged:
99COOP
Retired
Chicago, IL
Did you check the fuses? do you have barn doors, the metal contact patch on either barn door can become corroded and will keep them from working, if they are cleaned off they should work just fine.
Chevyrider619
Chevyrider619
Virginia Beach
yeah i have barn doors..You know what the other owner had them painted and i cleaned them out checked the defroster fuse too,so what do u think coop?? your hoe is same as mine..
AtomicHoe094
Atomichoe094
cleveland, OH
check your grid lines, make sure theres no breaks in those black lines. if there is, well it can be repaired to a certain extent. look and see whatcha find
Cmdrpopnfresh
so im curious about how to repair those.....i have a couple strips on my back windows that dont work....about 4 inches on the driver side window right in the middle....all the lines below and above work just those 4 inches dont work. same situation on the other window
haks310
Got LEDs?
SoCal
I have the same problem. Contacts and fuses are good, haven't checked the lines though.
How would you repair those if they were to be broken? Any other areas we can troubleshoot?
JeffK
