At a loss.
myself
Fuel issue. Start and stall 04 tahoe. Replaced everything but the motor mounts. Won't relearn electronic throttle body.
it's advisable to provide a LOT more details, we are not mind readers, you are leaving a LOT of information out
I mean it's like if I said it's 2 o'clock, we broke down, the wiring harness, gas tank full
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
To be fair, he/she did post the year.
Did you replace "everything but the motor mounts" because of this problem or was the problem after replacing the parts?
You replaced the throttle body? Did you replace the wiring harness too? What manufacturer?
admittedly that would suck if you had all brand new parts under the hood and it still wouldn't run, that would be a expensive adventure
which makes me think not everything has been "replaced" which means it is probably a figure of speech which can be interpreted in many ways
hence we need "more info"
nonickatall
Germany
Or everything, except the motor mounts, was replaced, but not appropriate assembled.. :p
In all seriousness, please provide more information on what your problem symptoms are, and what you have done (unsuccessfully) to fix the issue. Then, we can be MUCH more helpful to you in assisting you to resolve your issue.
nonickatall
Germany
After specifying the symptoms and considering all the facts, I think that it is another part that is defective and may need to be replaced or repaired.
But maybe not.
It would be nice if the thread creator could name the solution to the problem so that users who have another problem, even don't know what it's about.
A forum like this is incredibly helpful, when you don't know which car you drive.
Thanks for the fish...
Andylbc
