Are there any differential gurus on this forum?
ivin74
05 NBS Nali
Htown, Texas
My front diff is grinding at 20mph and lots of metal shavings came out when I drained the oil. What are all the parts that I need to buy to rebuilt the diff? I already removed the diff
05 Yukon Denali
Well, what is worn? Is it just the ring and pinion or are there any bad shims, bearings, sleeves, washers, axles, etc. as well?
ivin74
ivin74
05 NBS Nali
Htown, Texas
Don't know I have not opened up the diff, I'll find out later on today once I open it.
06Escalade
Same here. The PO didn't notice the diff vent had fallen off the fender well, down underneath. It was sucking in sand water and road salt for years! I researched it, going reman vs rebuild DIY. Because the skill and tools required to set the preload and backlash are out of my league. Approx $1k for plug and play.
afpj
Good luck bro, I am with 06Escalade...out of my league. I will live vicariously though your pics.
ivin74
ivin74
05 NBS Nali
Htown, Texas
So I finally got to open the differential. It looks like the carrier case spider washers and thrust washers are bad (the gears looked good) and I could see where the carrier case was wearing down, that makes sense why I was seeing metal shavings on the oil.
Watch "Spider Gear Assembly How To - Spider Gears" on YouTube
ivin74
ivin74
05 NBS Nali
Htown, Texas
FYI
The pics of the carrier case wearing down and the spider washers. You can see on the video how bad the washers are worn down.
bone
