antenna removal
ajs800
Michigan
Is it a simple process to remove antenna mounted to roof? Looking to remove and color-match to summit white but when quickly looking, not sure how easy it really is. Thanks!
fiatdale
Houstons Best
Houston
have to get on top of the headliner, then there is a 10mm bolt holding a clamp which holds it in. Should be a single plug above the headliner also to disconnect.
Used to be the paint interfered with the communications, but 2015i and above they paint now, so I'm not sure.
A
ajs800
Michigan
thanks for the info. Not sure I want to mess with liner and will have to check on the painted part.
CKendrick
