Another tire/rim question....(yes, I searched)
NDGuy
I'm looking at getting a new tire/rim combo for my Yukon (these tires/wheels:http://www.ebay.com/itm/2012-GMC-Si...&ps=63&clkid=82026997120731626#ht_4231wt_1037) or just get bigger tires on the stock rims.
Like I said, I did a search and couldn't find a good answer. If I got the 18" 2012 z71 rims with the 265 tires, would I have any problems with rubbing and would I need any back spacing? If I kept the stock rims (16") and got new tires, is the largest I could go around a 31x10.5 without rubbing? I looked into 275/70/r16 tires but there were very few options. I'd like to fill the wheel well a little more than the stock 245/75 tires.
Donnie Yukonie
Yates Caretaker
stock rims on 31s will not rub thats what i ran with no lift and no crank as for the new z71 rims i dont think you need spacers or anything and shouldnt see any issue running the same size tire on them either as the actual size of the tire isant any different
N
NDGuy
Do you remember what tire you ran? I'm looking around and can't really find anything I like. I've only looked online, though; stopping at some tire shops tomorrow after work.
Donnie Yukonie
Yates Caretaker
tires are in the sig pic same ones when i was stock and i have a 6 inch lift but sitting at five they are firestone destination M/Ts . idk if you are looking at offroad tires but i know there is a set of A/Ts that they offer and michellens that are that size i would check with firestone or goodyear
Fishintahoe
South Texas
I had 32's on a 15x10 rim and i had to trim just a bit on the front lower valance. and crank the t bars about an inch. Ive also had 285's on the stock rims and i didnt need to trim but it did rub just a little bit on the lower A arm at full turn. The 285s were Baja Widetrac.
Hope this helps.
letsbangout
You do realize those rims are 6-bolt and the 1999 and older trucks are 5-bolt, right?
Buford bubba
