Davyboy
Okay I've done what I can, my brain cannot fathom what could be wrong...
The Amp I have is a Sony Xplod Amplifier XM-SD51X - Class D 1100W Mono...
I've hooked up two amps for buddies cars before, and never had any problems, however the power light does not want to turn on indicating I have power, so I haven't hooked the sub up to it ATM...
So I'm going to list everything I have done, and maybe one of you can tell me that I made a mistake somewhere...
Removed Negative Terminal of battery, Removed Positive Terminal, Attached Power to Positive Terminal (without fuse). Ran this all the way to the back of the Kon, Next Pulled out Deck (sony) and looked for where to connect RCA (had only front and back components, so hooked to the back [this is going to work fine right?]) and ran this to the back of the Kon. Next found the blue wire (crimped to connector, other end open) this appeared to be the remote on, so crimped it in and ran it to the back. For the ground, connected it to the metal under the plastic/carpet right at the back. Then hooked to the amp in the order, ground, power, remote one, RCA. Then connected Positive Terminal of the battery, followed by negative, finally inserted fuse into power cable.
Any pointers?
Any ideas as to what is wrong?
HELP!!!!
Any pointers?
HELP!!!!
