Alternator
CDNTAHOE
Edmonton,Alberta Canada
Sorry if this is in the wrong section, but I can't figure out what alternator is needed for my tahoe. Is there a certain code for which one is in it and if so how do I find out which one so I can buy a new one. The old one is growling, to me it sounds like bearings.
dnt1010
Tennessee
looks like about 100 bones on rock auto for a acdelco 130 amp.......................
clandr1
Dallas/Fort Worth, Texas
Ya it has the 130 amp Delco.
I guess I'm missing what you need. Can you be more specific? You can literally log on any auto parts store website in existence and type in basic info and be presented with multiple options for various parts that fit your car.
wjburken
Eastern Iowa
That sticker (RPO code) will tell you just about anything you need to know about your Tahoe. Just google RPO codes GM
You can also contact GM through the chat feature on their website and get a full build sheet for your vehicle. That will give you a list of all the RPO’s for your vehicle and what they represent. Very helpful.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
So, high beams work but no low beam? Was working before for sure? All connections correct at the back of the alternator and make sure the plug in is fully seated and one of the pins did not push out of the connector housing. Is it at least charging? Did you check all fuses? Get in there and see.
CDNTAHOE
CDNTAHOE
Yes high beams work, all lights were working before the replacement, but I forgot to mention that this is the second alternator. What happened is I bought the first one it caused an overcharging situation, I checked the amps and it was putting out 18.65 amps at the battery while running so I shut my truck down. Called my mechanic and we both agreed that the regulator was bad. Took the alternator back to Napa got another installed it and all was good so I thought. I have the auto light option or what ever it is called when it get dark enough the exterior lights come on all the other lights work just not the low beams.
OR VietVet
Willamette Valley
I think you mean charging 18.65 volts. 18.65 amps from a 130 amp alternator will not do much damage. Your auto light that comes on when dark enough may have to be reset. Look at your manual for the process. Do the low beams work if you turn them on yourself? The low beams could have been damaged or there is a fuse or relay that was damaged by the over charging. But maybe, just maybe a reset will do it, if it can be reset.
Woned2004
