Air Lift System for Lift1000's
NORCAL SS
SUV SUSPENSION GURU
Air Lift Load Controller I Systems 25854
Anyone here run this set up before?
http://www.summitracing.com/parts/air-25854/media/images
i usually use airlift 72000 its wireless and works great. Here is install in one of my old trucks
That set up there will work fine for what you want just need to run gauge to inside the cab.
Goodinblack
I Like Tacos
Dirty South
That system is too powerful for the Airlift 1000's.
When I called them even they said so.
It takes hardly any effort to fill them up.
A
Andrew2944r
My thing is that I do not want to run one of those plastic covered compressors that cannot be mounted under the vehicle.
NORCAL SS
SUV SUSPENSION GURU
ive ran the 72000 on many of the helper bag kits ive done and i had it on both of my trucks never had a bag blow out. Its a overkill compressor but my customers like me like the fact its wireless.
If your going to keep the truck for a while spending 200 on a nicer set up its worth it or you dont need to run a compressor just use a portable unit to fill it up
A
Andrew2944r
I just like the idea of a compressor working to make sure 5 to 10 psi stays in the bags at all times.
NORCAL SS
SUV SUSPENSION GURU
If you like the system with wires in the truck and all that then get the cheaper one still will be good.
A
Andrew2944r
Yea it is a very nice set up. I am going to get all the weight slapped in the Tahoe and see how the bags work before I drop that on a 72000 which is the set up I will do. No hoses inside the vehicle would be nice, just wonder how well the block/remote works.
lfh2indiana
