AFM
Amaster
Laramie wyoming
Okay guys hear me out I'm a little confused on what the AFM thing is? Is it the stupid emissions crap that makes the oil pressure gauge go all over the place. Or is it the instant economy which yeah I can see it being I little ******* the engine but mine has over 160k miles on it and it does fine so I don't get why people complain if it's that except for the fact that it kicks back into v8 when you have to jump on it. I like it overall.
Active Fuel Management is the system that turns off half of the cylinders under certain conditions for improved fuel economy.
A
Amaster
Laramie wyoming
Will then I ain't going to worry bout it I don't mind it and I change my oil every 3000 miles anyhow so it's not like it matters
Sent from my SM-S506DL using Tapatalk
I believe that most of the conversations regarding AMF is that in the early years of this feature, there were mechanical failures that ended up destroying parts of the engine.
A
Amaster
Laramie wyoming
Eh I heard some people wanting to disable it in like 19s and all that eh I've done my research and I found out it disables itself when your in tow mode and like I said above doesn't bother me it's just a stupid gm thing lol jk
wsteele
Actually, I don't think tow mode disables AFM.
wsteele
Putting it into manual shift does, as long as you stay out of 6th gear.
I think where people get confused regarding tow mode is AFM doesn't function in the lower gears anyway (or at least mind doesn't), so with the higher shift points in tow mode, they never get to the higher gears to see the V4 switch appear. At least, that is how I was fooled when testing the tow mode theory.
BG1988
Yes M1, M2 M3 ,M4 disables the AFM on the hybrids it's still better to use a disable chip as you get access to the SUN overdrive gears and autostop... while in M4 it's locked out... i was getting like 17 in m4
with the chip i get 20 city and 25 on the highway (same highway mpg with AFM v4) with 91 octane
mpg is pretty consistent
Melissa1971
