AFM delete by dealer?????
soulsea
Bar
Active Fuel Management. It switches to 4cyl mode when it doesn't need 8 to maintain speed.
If you have it, there's display setting on the DIC that shows how many cylinders are active ... not sure if the 08 were six speed transmissions, I believe (but I'm not certain) that AFM is relevant to the six speed.
Blazed
Accepting Donations
I'm about 99% sure 6.2 Afm started in 09.
I've researched it a bit when I had my tahoe.
And I know for a fact my 08 Denali doesn't have it and I have a 6 speed.
6.2 has had 6 speed since 07
Ponchonutty
New Washington, Ohio
Ahh, gotcha. I this is what I was thinking. BTW, my '08 does have the 6speed but I never feel it nor see it in the DIC that it's switching down to 6, 4 cyl.
TheFuzz
Idiot Police
Spurbury, VT
There is no 6 cylinder mode. It goes from 8 to 4, that's it.
If you have AFM, when your DIC is set to "Instant Fuel Economy", you'll see the MPG you are currently getting at that moment and another icon that says V8 MODE or V4 MODE depending on what the engine is doing.
tights24
For the 5.3, it's not limited to the 6speed. I have an 07 with a 4 speed and have AFM. Just some info.
This is actually the first that I've read that this is directly proportional to me burning a quart of oil every 3K miles though. Interesting. Will need to be looking into a tune sooner rather than later now.... Crap.
Goodinblack
I Like Tacos
Dirty South
I have always been big on saving gas, not for liberal reasons....... but because I am cheap to a certain extent. This AFM causing oil consumption has made me rethink the whole thing though.
White knight
Ohio
Yeah, there are a multitude of posts on the other forums where silverado guys go through pretty good explanations of what happens when it goes to v4 mode and why lots of highway miles in that mode makes it more likely to be an oil burner after 50k. My suburban started almost exactly at 50k and we are going through the oil burn test right now. On mine, the oil doesn't even register in the dipstick 1500 miles after an oil change.
Fortunately, it is well under warranty and I seem to have a helpful dealership.
For what it's worth, there are also a large number of posts from others with the same 5.3 engine who never had it burn a drop. And, it doesn't appear that the oil burning causes any other problems in the engine.
IMO a bb tune is worth every penny! Just AFM delete alone is not worth much but be complete package of having AFM tuned out along with the other improvements make it feel like a brand new ride!!! :driver:
harveje
has NE1 tried a product from rangertechnology that is "suppose" to override AFM or DOD
White knight
Ohio
Yes, and it works exactly as advertised. Got it from auto anything for 15% off. Same mileage in the Denali vs stock.
04ctd
Charleston SC
has anyone had the Dealer to replace the engine internals with the GM Kit?
my AFM on the 2013 killed the motor at 44k miles, and we got a 2016, the AFM on the 2016 5.3 6spd is in V4 mode ALL the time, and makes a huge res waonance, it's sounds like you are running over rumble strips every time you slow down in traffic and try to catch back up.
is AFM noise a warrant-able item?
another question: how do you know if the engine is out of oil due to AFM consumption? does it have a light on the dash, or just blow up the engine? our 2013 was having problems a while before my wife thought to mention it to me.
good comment on tuning it out, the AFM lifter can still fail:
https://www.summitracing.com/parts/...-performance&gclid=CKis6r-GudECFYhKDQodnfMDQg
"Had the AFM deleted with a programmer but the lifter still went bad. Used this kit in my 2008 5.3l silverado and it went in flawlessly. Used the COMP XFI cam and springs and made the tired old beater into a new towing machine"
Dank Denali
So it seems like the 6.2's don't have issues with AFM? Planning on getting a tune at some point, is it recommended to disable AFM on the 2013 Denali or leave it alone?
Durobans
