Adjusting Stock Torsion Bars
willua11
Alabama
I have noticed lately that my 2dr is starting to sag a little in the front and I am just interested in leveling her out a little bit. What tools to do need to adjust the stock torsion bars? Special nuts? Will it require a cheater bar to turn them?
willua11
willua11
Alabama
So if all I want to do is crank it up some, I just need a 18mm socket?
bowtiefreak
No Quarter
Near Philly
correct....I recomend an alignment also. Plus get teh truck off the ground in the front, it makes it easier.
bowtiefreak
No Quarter
Near Philly
Make sure to spray them down with penetrating oil the day before....maybe a few days before and each day....trucks are old!
willua11
willua11
Alabama
So, when doing this lift is there any point at all in getting new key?
If so, is there a place I can rent the chevy torsion bar removal tool?
petesone08
Frontenac Minnesota
you dont need new keys unless the hex where the bar slides in is worn out, you dont even need the tool if you have it off the ground you should be able to back the bolt all the way out then lift the key by hand and slide the bolts housing out and if you cant a c-clamp works just fine
bowtiefreak
No Quarter
Near Philly
Our year trucks typically do not require keys to gain too much lift as the newer body style trucks do
willua11
willua11
Alabama
So the tool everyone talks about to take the torsion bar off isn't necessary?
