AC Compressor Not Pulling Freon
Gregski
Please help I am at my wits end. I have a four door 97 Tahoe with only AC in the front. It was blowing warm air so I "evacuated" ;) the system and then put a vacuum on it with an actual vacuum pump (instead of using an air compressor and that red mickey mouse vacuum conversion pump thingie like I tried before) vacuumed it for 25 minutes then shut off the valves and let it sit there for 30 minutes. It sat and held the 40 PSI vacuum just fine.
FIRST ATTEMPT - Plan A
Then I connected a 14 oz can of freon to the middle hose and expected it to get sucked in without even turning the car on, but it sucked a bit in then I had to start the car and blast the AC and the clutch would not spin.
SECOND ATTEMPT - Plan B
So I disconnected the gauges and connected the can with one of those quick charge blue hoses with a dial on them directly to the low side service port and ran the engine and after what seemed like for ever finally the clutch started engaging for about 5 seconds then shutting off and cycling off and on like that, but still not pulling any freon.
Just so you know I have charged this car and others like this in the past, well... before that stupid blue base cap came out that they make you put on the cans now first before connecting the charge hose to them. And yes I do have the blue base cap and I am using it, but something just aint right.
Please help.
gpracer1
Phoenix
Did it have freon in it originally?
Did it just stop blowing cold suddenly?
With the gauges on, at what psi does the compressor kick off, and back on. Sounds like possible ac cycle switch.
Phone Man
Long Island NY
I had to jump the pins on the low pressure switch which is the plug on the Accumulator. This will engage the compressor and allow the freon to enter the system. Also you may need to add some PAG oil? I replaced my whole system and had to do that.
G
Gregski
Yes
No over a couple years the air got warmer and warmer. Till I finally got motivated to do something about it.
25 PSI both High and Low sides
Does that bad boy have a shrader valve behind it so I can remove it and not lose any freaon that did go in and have to vacuum the system AGAIN
---------- Post added at 02:45 PM ---------- Previous post was at 02:42 PM ----------
Thank you I tried that with a paperclip.
One of the 14 oz cans I bought claimed to have had the oil in it
gpracer1
Phoenix
Yes the switch has a valve behind it.
Try turning the can upside down on the first one or two. That should help it cycle less.
JenneK
Island of Maui
Wait...wait... marc, where is this "AC cycle switch you speak of??
I was informed that our trucks have a low pressure (on accumulator) and a high pressure switch (on compressor) with the actual cycling being controlled by the PCM.
My brand new compressor runs all the time EVEN WITHOUT the AC on! I had to rig up a switch so that I could cycle the compressor manually. It works but it's kinda a PITA.
______________
Gregski, you may need to change the orifice tube/expansion valve. Maybe yours is mucked up after no use for so long.
gpracer1
Phoenix
______________
The ac low pressure switch controls how cold the evaporator can get. It usually shuts off at 25-28 psi to protect the evap from freezing up in humid environments. For this reason your ac will never blow under about 34 degrees. I installed an adjustable one in mine since I live in a dry area and have it adjusted to blow down to 23-24 degree air.
If you look at a 134a pressure/temp chart you will see, they are directly related.
G
Gregski
Well I bit the bullet and bought a brand new $200 dollar compressor and installed it (yes did the PAG oil thing, and new O-ring gaskets for the hose manifold, etc). Vacuumed the system and let it sit for about 45 minutes and it held the vacuum perfect. Then I hooked up a 14 oz can to the yellow hose on my gauge set and opened the valve and it sucked a lot of content into the system, but when I turned on the car the compressor would still not engage, so I shorted the cycling switch plug by the accumulator (silver coffee can looking thing on the firewall) and the clutch engaged but it still would not suck more freon in, then I plugged the low pressure switch back in and the clutch now engages for 5 seconds just like it did with the old compressor and then disengages, then it repeats that for eternity
well at this point I don't know any more, what does it mean when the 14 oz can feels cold and has condensation no it, does that mean it is pulling freon out of it? and it's just going to take for ever, shouldn't it be done in 10 minutes or so?
Shouldn't the low pressure hose muffler get cold to the touch, it is not?
Could it be the pressure switch in the high pressure hose line, is it not opening some valve which would allow the system to suck in more freon?
letsbangout
The only way you're going to get more than half a can of freon into your system in any reasonable amount of time, is by running the compressor. I personally have never seen the need to jumper the cycling switch (and in fact, if you left it that way and you had a leak, your brand new compressor could blow up). The only reason to jumper it is to save time, nothing more. From what I recall, charging my system would take the first full can about 10 minutes to pull in, the subsequent cans would take about 7 or 8 minutes. Yours needs about 3 full cans for a full charge, so just be patient and wait for the compressor to suck it in.
You are charging into the suction (low) side, right?
G
Gregski
thanks letsbangout so just put a can on there and even with the compressor turning on and off every few seconds it will still suck in the freon from the can, I think I will buy a better quality short yellow hose from NAPA that goes from the can right into the low service port rather than using my cheap harbor freight gauges and the long middle six foot yellow hose that is attached to them, (that's too much room for air to sit in and re enter the system) and it should be way better than the silly blue one with the gauge on top that comes with some cans when you buy em that way, called a shop today and they quoted me up to $1,200 bucks to have it diagnosed, troubleshot, fixed, evacuated, vacuumed, pressure tested, and re charged. I am trying to do it for a third of that cost myself.
My only worry / concern now is over filling it, but at 25 PSI I am a long ways away from the 60-70 PSI on both sides when equalized and full with engine off. Or the 20-30 PSI low side and 120-170 PSI high side with the engine running and AC on obviously.
99tahoe5point7
