ABS fuse causing motor sound by engine
mattluttrell
Hello,
I've just purchased an 02 Escalade that had the ABS and Brake lights lit on the dash. He told me they worked but it was just a light. Before I bought the truck I had read all of the EBCM ground threads and assumed this was my problem.
I opened the fuse box and noticed that the ABS 60 amp fuse had been pulled. I put it in and my Brake warning light disappears but the ABS light remains. I then observe a motor spinning noise near the engine.
Anybody have any ideas?
Thank you,
Matt
---------- Post added at 11:50 PM ---------- Previous post was at 11:48 PM ----------
Crap. Just read this was a failed EBCM. Wish I could delete this post...
jomulk56
Resident Lurker
IN
I have the same issue and you're right. If you're handy and can get it off yourself the repair is fairly cheap. There's an ebay seller that repairs yours for under $75 shipped both ways.
M
mattluttrell
Do you know if we can drive our trucks without the module? The instructions looked like pressure sensors and lines needed to be disconnected.
jomulk56
Resident Lurker
IN
Yeah. Remove the 4 screws, take the computer off, wrap the abs unit in tin foil/plastic wrap really good and you're set
Drewphil
