checked everything that i thought would make sense
i was checking to make sure all fuses in the cab were good, and when i checked #14 illumination with the key turned on, the truck started right up, wtf,this is without turning the key over, just in the on position, also with the key between locked and on, the shift indicator works, but when i put it in the run on position the light shuts off
again all help is very much appreciated
