letsbangout
- Joined
- Dec 3, 2010
- Posts
- 74
- Reaction score
- 0
I'm trying to track down an issue with my Yukon SLT. This is like the third time I've had trouble starting it with the engine cold (but still warm outside), and it's gotten progressively worse each time. The first, I had to turn it over 4 or 5 times. The second, I turned it over countless times, to the point where I thought it'd be flooded, so I went and had lunch and came back 45 minutes later, it started up just fine. This time, I'm not so lucky.
After instance #1 and #2, I had codes illuminating the Check Engine light. I've had persistent problems with the O2 sensors (which I'll have to replace eventually), but I now had a new code both times - the MAP sensor. I replaced the MAP sensor yesterday with a Delco replacement part and I still couldn't get it started. So I disconnected the battery, waited 30 minutes, connected it back up and it started the first time. I ran it like a champ for probably half an hour, took it to the gas station and dumped like 9 gallons of fresh 93 octane on top of the 3 or so gallons it had before.
This morning, I went to start it and the same thing - it turns over and fires up, but will not run for more than a second. I bought a code scanner which reports no codes. I also had someone turn on the ignition and I can hear the fuel pump in the tank running for 2 to 3 seconds initially. But I'm still suspect of the fuel pump and the oil pressure cutoff switch. That I can troubleshoot, I just can't get to it because the distributor is in the way, so I can't see it either. The only way I'd know where it is, is because a friend sent me an engineering diagram showing it on the driver's side behind the distributor. I thought of pulling off the connector and jumpering across it to enable the fuel pump full-time, but I'm still not sure it's the right connector I'm pulling off, as the colors don't correspond to the colors in the wiring diagram, so that's out (unless someone has a wiring diagram showing colors other than my Haines book, tan/orange/grey - still the prospects are slim because I can hardly get to that particular cable because it's so short).
So I'm looking for some troubleshooting guidance. I suppose I can buy a fuel pressure gauge, but I'm also very limited in what I can do in a public parking lot, which is where it sits now. I feel like any more money/time into trying to fix it myself under these circumstances would be futile. However, any advice is much appreciated. Thanks!
