99 Tahoe
red02chevy
Lubbock
I sold my 96 extended cab and picked this up as the replacement. It is a super low mileage 99 LT Tahoe. I really wanted black but white is a better choice for daily driving. Going to do the usual on it. Low static drop, helper bags with air mang, clean up the exterior, metal flake roof, radir wheels, etc etc.
The rear suspension on these are really hard to work with since there's several crossmembers in the way and the shock mounting leaves you with pretty much no choices in aftermarket drop shocks. I have figured out a pretty trick way to do relocate the shocks and add helper bags. I ordered everything so as soon as it comes in I will get started on that. Also replaceing front end ball joints, tie rods, doing an aftermarket sway bar and will be doing quite a bit of powdercoating.
Should look good when it's done. :)
Drewphil
