97 tahoe
destroyer1362
A work in progress
Midlothian, TX
I've got a random misfire and a multiple random misfire and only a solid light when its been idling for a while. You can hear it in the beginning of this vid.
[yt]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/t9WbcyNP2lU&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/t9WbcyNP2lU&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/yt]
update: Needed new fuel pump.. or so my mechanic says
stykthyn
panama city florida
dealer says a blinking check engine light means that is when the engine is misfireing, yes a bent push rod can cause this I agree but wouldnt i hear it knocking?
depends how bad it was bent. I would at the very least do a compression check and a cylinder balance test on all cylinders. When I missed a shift and over -revved my Ls1 only 1 rod looked like a hockey stick, but I had three others that were very obviously not straight. If its a higher mileage engine then you may also want to look at some new valve springs.
M
Tennesse
its got brand new heads and valves plus springs and for giggles i did pull off valve covers tonight and check the rods they all seem fine one weird thing on compression test cyl 2-8 read 180 but cyl 1 is 190?
ZaZaZazzels
