recenty a friend bought this 1997 Tahoe. We started to drive it home and about 3 miles down the road it lost all power. It would then try to turn over but couldn't quite. So we needed up tighten all battery connections and it fired up as it was a new battery. Got another 2 miles down the road and I was behind him and noticed when he would stop and then take off it would puff out little black smoke almost like a diesel. Anyways then it dies again. He thought it was the alternator was bad so replaced it and the starter as well and fired up. Then goes around the block after about an hour of driving around and noticed no oil pressure on his gauge and had some tapping/knocking but still ran fine. Was told that the crank position sensor was bad so he is replacing that in the morning and was also told that the distr. cap was new but was some cheap off brand from auto zone so was told to buy an Ac Delco and see if that helps and also check the oil pressure sensor since its behind the distr. has anyone had any of these problems and if so what could be some causes and/ or some things we can look at to fix them
Thanks
Thanks
