95 yukon fuel gauge
DIAZ
The fuel gauge on my 95 yukon jumps like crazy when the tank isn't fuel, I've changed about 3 clusters and they all do the same thing. Can anyone give me some imput on what might be causing the gauge to act this way?
McFizzl
Broke as a Joke.
Fayetteville, AR
Mine goes nuts too. When you first start it up or being stationary you can get a good reading on your fuel level. Thats what I do.
DIAZ
DIAZ
I mention it because I never had that problem before.
McFizzl
Broke as a Joke.
Fayetteville, AR
Only thing I could refer you to is to search for the thread on it. It will take you to GMT400 and a guy put oil in the gauge to settle it down. Sun probably knows the thread Im talking about.
95BlackTahoe
Edinburg, PA
My fuel gauge does the exact same thing...but only below 1/2 a tank. My friends tahoe limited does not do it at all, even with 1/4 tank. I read someplace that the solution to my issue may be nothing more than getting rid of the airtex pump and putting in a new delphi.
Shawn
SunlitComet
OBS Jedi-Do Good
unknown at this time.
delphi are better but they still do it too. the 4 doors have it worse because the have a long fuel tank front to back and it does not have baffle in it.
96redsport
Altoona, Pa.
I have a 2 door and never had a problem with the gauge bouncing around when the fuel inside moved until I had the pump and sender unit replaced last year. Doesn't matter how full the tank is, drives me nuts..... :banghead:
Any suggestions??
96redsport
Altoona, Pa.
That's what I do. Just don't understand why it's doing the crazy movement when the old assembly didn't.....
La rabona
Houston Tx
Same thing with mine ... Under half tank starts acting crazy .... Didnt do that before just started a few months ago
RedCrush
mine reads pretty well, but when I have about 1/8 of the tank and brake hard, the hoe shuts off. Then I simply throw it in Nuetral and restart after I stop or simply avoid hard stops... hahaha
AZ Tahoe
Arizona
I wonder if anyone has ever considered replacing the fuel tank with a newer modern tank with better baffles?!?!?!?!
danny's 97
95 yukon fuel guage
My neighbor is a master mechanic, he said it is almost always the sending unit on a long tank.
mfinta
