93 yukon doors hard to shut
Stewy
the drivers door is very hard to shut. almost like it needs re-aligned or something. if its not shut all the way the body lines are off a little. any ideas?
992door
Greenville, NC
Doors pins probably need to be replaced and probably the roller pin also if it is bad
bowtiefreak
No Quarter
Near Philly
Agreed. Rather straight forward job. to check this, open the door and then try lifting it upif it moves they are bad. Watch the hinges when you do this. The door latch may also have the wear strip worn off.
The pins and bushings go bad since it is a heavy door and people lean on them entering the truck and they wear faster.
S
Stewy
Looks like im going to be looking for door pins and bushings. Thanks guys
AdrienR
