87 or 91 octane gas
Nagloc68
I searched the forum and couldn’t find a related thread. If there is one, feel free to point me to it.
Original Owner of a 2013 Yukon xl Denali with 191k. Original car, well maintained but stock, original tune so maintains the V8/V4 feature. We have used 87 octane its whole life. Have been reading a bit and have interpreted some comments suggest 91 octane is preferred. But it has always been about $1 more a gallon which is why we used 87. Most of its gas has been purchased at our local Costco which is top tier. 91 is currently $5.23 at Costco!
Engine drives strong and hasn’t caused any concerns. Much of my miles are highway miles. My question is at 191k miles is there any reason to change the octane of gas I use?
Thanks
donjetman
If you want to extend your range/mpg? run premium. In our Denali (mostly hwy) premium pays for itself.
GM recommends premium with our 07 6.2L L92.
I experimented w/87 and 89 unleaded and gas mileage suffered and I got an occasional "Knock Detected" on the digital info center, not good.
Your vehicle may have lower compression and be tuned from GM for regular? In that case premium would have no effect
Thanks
Many threads and opinions on this topic, and it has been discussed ad nauseum on this Forum. I did a quick search, and surprisingly, I found very little on this topic, just as you experienced. We really need a better search engine on this Forum.
Bottom line, some use 87 octane, but most use 91 octane, as recommended by GM. If you are at 191k miles using 87 octane without any issues or knocking, then I'd say keep on using it.
Thanks
your good, no reason to start paying more now.
if you want a tiny bit more giddy up use e85 if you have it available, you might not feel the difference though
Foggy
KS
It's a high compression engine.. So it requires 91 octane. Just like
it says in manual.
IF you run lower octane, it will knock/detonate... Then Ecm will adjust to
the low octane spark table (of course after some knock-bad- is detected)
It will stay in that low octane table and your gas mileage will suffer.
So it's up to you to justify what it wants - 91 octane
You can risk knock/pre ignition/detonation and worse mpg OR
just put in what it's designed to run
mikez71
I thought that was one of the benefits of the 6.0 over the 6.2, to ability to reliably run regular gas?
Though being at 191k on the 6.2, that sounds pretty reliable...
the 18th letter
Northern New Jersey
Thanks
At 191k with AFM enabled I can’t think of one reasonable argument to change octane at this point. Not one…this is assuming you haven’t rebuilt the motor at any point already since you said ‘original car’.
Foggy
KS
Yup . The 6.0 in the 2500hd has the cast iron block and lower compression
Also NO DOD and a little diff cam profile than the 6.2
So it doesn't need the higher octane
Bill Barnes
Catlett, VA
I read all of the replies on this thread, and agree with most of them. Here in Virginia, we have a convenience chain called Sheetz, and it offers an 88 octane E15 gas that is always about 40 to 50 cents a gallon less than the 87 octane regular E10. The pump handle and selection button are color coded in blue. My 2005 Yukon XL 5.3 FLEX Fuel 4X4 likes it just fine. I have 300K miles on the vehicle, and I've been using the 88 octane E15 for 100K with no problems, and maybe a tiny bit better mileage, maybe 5%.
donjetman
Ethanol has less energy (BTUs) per gallon than gasoline so mileage/range suffers, but it cheaper.
I've run mixtures of as much as 30% ethanol and no issue(s).
Dh1280
