7" Drop Springs??
NORCAL SS
SUV SUSPENSION GURU
Would anyone be interested in a 7" rear drop spring for the 00-14 gm suvs??
Will require c notch for sure but just seeing if there is enough interest here ill look to get them made like the 6" ones I currently have.
LoHoe
Tony man I hate you lol!! Now you going to make me go lower in the rear haha
tsb09000
Thread Killer
Any idea on a rough cost if there would have been enough interest?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
235-245 shipped if i could get enough people
tsb09000
Thread Killer
Damn, if I'd seen this earlier I might have put my name on the list
LoHoe
you know Im down tony. Just keep me updated
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
If I did the lower version of mine you guys would need to c notch the frame also c notch the upper cross member for the panhard bar clearance. In order to do 1 run i need 150 sets and I can;t afford to do that right now.
Sidenote you guys can cut the springs i currently have off the top loop. You then use heater hose and wrap it on the first coil so wont make clanking sounds. MAKE SURE YOUR RUNNING A SHORTER SHOCK AND SHOCK EXTENDERS WHEN YOU DO THIS SO THE SPRING DOESNT FALL OUT WHEN YOU LIFT THE TRUCK OFF THE GROUND
vdesolution
