58k on yukon denali xl and front shocks are gone
Inastrangeland
I’ve read most pf the posts on here regarding magneride shocks. Some were saying gm has a lifetime warranty on replacements. I went to gmparts direct and it syas 12 month warranty. I need to replace them but don’t want factory replacements that will go out in another 50k. I am open to magdelete options also.
CMoore711
Do not recommend mag delete options…
If you go cheap you’ll get the exact ride quality that you pay for.
You are essentially “tricking” the OEM electronic suspension system which creates its own risks and problems.
You’re essentially taking an engineered active suspension system and reducing it down to a simple plain suspension system; What that means is if you still want it to ride as good as it did when it was new you’ll spend a lot of money trying to do that.
The reduced resell value far outweighs what $ you think you’re saving.
Deleting the magnetic ride control is really only beneficial for extreme off-road applications. Which when done correctly are more expensive than OEM magnetic ride control shocks/struts.
Use your vehicle year make model and VIN info and you’ll find the best prices on OEM replacement parts on www.rockauto.com
There’s also a thread on here where a lot of forum users post their rockauto coupon codes which will at minimum get you an additional 5% off.
kikeap
