4x4 not working(update now working)
Hello, I have read through all the 4x4 posts I could find and I don't see any that answers my problem. Let me start off with what was happening last winter. Oh BTW I have a 99 GMC suburban with the auto 4wd transfer case.
Last winter when I would put it in 4wd it was making a bad noise(almost like a wheel bearing roaring) but the 4wd was working then. The other strange thing that it was doing while in 4wd is when I would accelerate the steering was scary...I mean it was like only one front wheels was driving it. Not sure why I only had noise when it was in 4wd. I did replace the pitman arm since then so I don't know if that was part of the steering problem or not since I have not been able to get it in 4wd since replacing the arm.
Then in the spring one morning on the way to work the Service 4wd Light came on and then I could not get the 4wd to engage. I had no lights on the switch excect for at start up when all the lights will light up for a few seconds and then go out. So I started doing research and found the 4wd push button switch is a common problem. I found one out of a parts burban and swapped them and nothing. I can't even get the other switch I got to light up at start up. So randomly the indicator lights on the orignal switch would come on. One day I pulled in the driveway after work and the switch was lit up so I pushed the switch and I could hear the actuator on the front axle moving but it would not engage, the actuator would move but all that happened is the lights on the switch just blink.
Now for the past month I get nothing, the lights on the switch will not light up. When I push the switch I get no movement anywhere. I don't know what to try next. I don't know if the t-case switch is bad, or something in the front axle is not allowing it to engage or if the tccm is bad. Since the switch did work for a short time and I got movement at the actuator that really confused me.
I know this is a long post, sorry. I hope one of you could maybe point me in the right direction to go next. Thank you for reading this.
