4D Tech Auto start install on 25 denali
dukecharmary
2025 Yukon Denali, For those installing the 4D Tech auto start eliminator, the install videos do not cover the 25 denali trim. After pulling the fuse cover and the side cover, remove the 2 -7mm and then raise up the leatherette trim directly above the vent. This will give you access to the 2 -7mm under it. The entire panel comes out to easily install the harness.
AZPatriot1963
