45K Maintenance
Bunty
Hey everyone,
I'm trying to find out if I require any specific maintenance on my 2011 Escalade. I was told I need a transmission flush but not sure if it needs to be done at 45K or 50K. I have almost 47K on the clock now.
Do you know what I should get done?
JML07denali
Don't do a flush. 50k maintenance - Have the trans. pan dropped and cleaned, new transmission filter and top off what you lost from the pan. The problem with a flush is may loosen particles that will make its way through the transmission and could lead to transmission failure. Just my 2 cents.
ScrewbenSS
Is a trans service and filter the only thing due at 50k? I'm getting ready to do some work on the truck and am looking for maintenance recommendations for 50k.
I figured I would do front and rear diff's along with belts and hoses(also coolant).
JML07denali
I replaced air filter, radiator flush, brake fluid and front/rear Diff fluids. It wouldn't hurt to change out your belts they are easy to replace.
briannorris
