MBradenC
I've been looking around (yes I've used the search box) for information on running a 35" tires with a 4" lift kit. All the information I've found regarding it has simply said go with the 6" instead. I don't want to hear about that unless it is honestly necessary. I know 35s will fit on a 6" lift. You can get up to 37s. I'm wondering just how much modification would need to be done to make them run comfortably for 70/30 street/trail with the trail not going much past a Moab system 4 or 5 (no super heavy flex, etc.). Typically I'd install the lift and then find a buddy with the wheels and tires similar to what I'd like to run, but I don't have the resources for that. In fact, if feasible, I would like to do the modifications to fit the tires before even lifting it etc. Whatcha got y'all?
