2in. Leveling Kit Tire Size
scottbrew92
South AL
I have a 2015 Yukon Denali 4x4 and have found some 285/55/22 Nitto Ridge Grapper tires. I know they’re a couple inches bigger than the 285/45/22 so will a 2in. leveling kit clear these tires?
STORMIN08
this is a 285/55/22, this is a 2.75" / 2" kit...with minor trimming (IIRC)
STORMIN08
i do not recall...that pic was borrowed from this site.
i need to look back to confirm, just recalling my search for lift / tire size, this had the look i wanted with the tire size i desire
Powder Toast Man
Do you have the factory power steps?
If so you will have rubbing on the end of the steps. I test fit some 305/55r20 and they would not fit when turned. 285/55r22 are even larger. I have seen people with amp steps having better luck because they don't extend all the way to the fender well.
scottbrew92
scottbrew92
South AL
Yes I do have the factory power step…. may just stick with the 285/45/22’s, don’t want any rubbing.
STORMIN08
the power step end cap is easily removed and the board can be trimmed to length
MADDOG54
