ClayCollins
- Joined
- Aug 15, 2023
- Posts
- 21
- Reaction score
- 11
I received the L87 recall letter several months ago, but for some reason my dealer says GM has not released my Yukon to be inspected. I was due for an oil change and they refused to put in the 0w40 oil saying it was being reserved for the recall vehicles so I had to put in the 0w20 - seems stupid. Is GM trying to stretch out these recalls so as to not overwhelm the supply of new 6.2's?
Also intersting - my service writer told me the recall was a 4-hour inspection process because they had to pull the plugs and check compression in all the cylinders. I've not heard of them doing this anywhere else. This seems odd because if there was a connecting rod bearing issue, it would not show up in a compression test! Seems like they should be dropping the pan and checking the rod bearings. I only have 35k miles, but when I eventually have the recall done, I'm wondering if I should just have them replace the plugs while theyre all out. Theyre about 1/3 through their life, but the labor should be close to zero. Any thoughts?
