2022 Tahoe RST Windshield Washer Fluid Stopped Spraying.
MissFrost
Northeast, USA
In my ‘22 Tahoe the windshield washer fluid will not spray out. The wipers still move but no fluid. I made sure to add fluid (to the top) even though when it’s low my car will alert me. Never got an alert, just added more fluid to see if maybe the message just didn’t pop up. It unfortunately wasn’t the problem. Any suggestions/help? I feel like it’s too new for the pump to be gone already.
StephenPT
St. Helens, OR
Pump failure has happened to a few other members here. Maybe a bad batch of parts? We won’t know for sure, but the pump is about $20 and 20min to take out the fender liner, replace pump and reinstall the liner.
GM Part #84801575
Does your truck have a rear windshield washer? On my 07, I have both front and rear washers, and they both have their own washer pumps. If one of your washers work, and the other does not, that would be helpful information to us.
Also, have you placed the truck on a hard surface (paved driveway or concrete garage floor) and then held the non-working washer button pushed down/in for about 20 seconds, and then checked outside the truck for any washer fluid on the ground? These washer lines have push-on couplings, and they have been known to come undone (happened to me).
StephenPT
St. Helens, OR
21+ platform uses a single pump. Two outlets and the pump runs in reverse to send fluid to the rear wiper arm.
rhsjr25
I have the EXACT same issue..‍♂️
Blanch44
Oswego New York
Same Issue here '22 Tahoe LT 40,500 miles ! Guess they don't make em like they used to ! '15 Tahoe 140,000 miles never had this issue !
Blanch44
Oswego New York
Good Video , going to have to go though wheel well on my Tahoe as there's no room to get a hand in from up top .
Blanch44
Oswego New York
Probably going bad with where they are located . Salt and road grime get up in there . Another bad design by GM !
Durobans
