2021 Tahoe crank-no start
Donnation
My 2021 Tahoe Z71 after just being in the dealership for a month due to a software error now has another issue. Yesterday it just all of a sudden wont' start. The engine cranks but it won't turn over. Any ideas?
Of course this is after I put it in the garage literally to move it out of the way for a few minutes. Now its going to have to be drug out by a tow truck I guess because the f-ing geniuses at Chevy didn't give you a way to put these pos vehicles in Neutral without the engine running.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Is likely gonna have something to do with software update that just took place. But who knows. Need 4 things for the engine to start and run. Spark, fuel, compression and air. IMO, you also need the engine to be in time and that software update can be messing with that. You did not say what issue the vehicle was having that caused the need for the software update. Frustration, yes. Ask for a loaner vehicle and hopefully you have been keeping all documentation in case a lemon law case is needed. Is this problem and the software update the only problems?
By the way, @Fless is correct, as usual. When describing the problem it is important to have the correct terminology. No crank means engine not spinning or turning over and is a no crank/no start. If cranks and the engine will not fire off and run, that is a no start. That is a crank and no start. Several different scenarios enter in to the equation depending on the correct explanation.
Donnation
Donnation
Sorry to hear of your woes. To be clear, the definition of "crank" is that it turns over. What yours seems to have is a "crank - no start."
Hmm, I said in the title the vehicle cranks but won't start. Doesn't that imply crank-no start? Just asking as it seems pretty clear to me. The engine is cranking but it won't turn over.
Semantics I guess, thank you for the proper terminology. Doesn't change the fact that this vehicle sucks.
StephenPT
St. Helens, OR
There’s been a few members that have had similar symptoms and it turned out to be the fuel pump control module. It’s mounted mid-frame, drivers side. There was a recall for some 2021s for this issue, but I don’t believe they captured them all because I’ve seen 2022s with the exact same failure.
Donnation
Donnation
Thanks for that. Mine's not showing up on the recall list but from reading it seems like the exact issue its having.
WalleyeMikeIII
Sunny and Snowy Minnesota
I can tell you I thought my vehicle had this issue once...turned out the floor mat was pressing on the accelerator...vehicle won't start if the foot is on the gas...
Back story is it did it at the car wash, and when they put the floor mats in, they had it ver the gas pedal...I was all flustered, unhooked the negative battery terminal, etc...still no luck...finally noticed the floor mat was on the gas...
OR VietVet
Willamette Valley
You just repeated again what causes the confusion. Your title says, "Crank-no start". That is clear and gets to the point. Then you say, "The engine is cranking but it won't turn over". That statement causes confusion. The "won't turn over" is the direct opposite of "engine is cranking". YOU may feel that it is no big deal but when asking for help, the details are important to make sure we don't go down a rabbit hole with recommendations.
When I ran shops for 25+ years, I asked detailed questions and I made a point of making sure I understood the exact concern, so I did not have one of my techs going the wrong direction with a diagnosis. Be mad at your vehicle. No problem. Mixed messages. Problem.
Donnation
Donnation
Understood. What should I be saying then? When I press the ignition button it makes a clicking sound like it’s trying to start, but it won’t. It’s just makes the initial sound over and over again until I turn the ignition off. Is that better?
Also, I think once they attempt to start the vehicle they will understand the problem. There won’t be mixed messages.
Donnation
Donnation
HOLY ****!!!! THAT WAS IT!!! I was cleaning out the vehicle last night and as soon as I read the what you wrote I drove straight to the dealer and got ahold of my keys before they had taken it back. Sure enough the floor mat was resting on the gas pedal.
Thank you so much. I can’t tell you how happy you’ve made me. Cheers to you!!!
OR VietVet
Willamette Valley
Ok, just to be clear. When you make a statement like "when I press the ignition button it makes a 'clicking sound" like it is trying to start, but it won't". That statement tells me that you push a button or turn a key, makes no difference, and then the clicking sound tells me that the problem is like a starter problem or low voltage problem, like a low battery. That is telling me the engine is not spinning/turning over. That is a whole other set of concerns.
1. Turn key/push button and nothing happens, engine not spinning at all.
2. Turn key/push button and hear clicking and engine not spinning at all.
3. Turn key/push button and engine spins and will not fire off/start running.
4. Turn key/push button and engine spins and dies when let go of key/let off button.
5. Turn key/push button and engine starts and runs but runs rough/misfire/cel on/low on power/idles erratic......etc.
All of these are legitimate concerns and the statements leave nothing to doubt when trying to describe the problem.
alanrcone
Thank you thank you thank you. I was just about to call a tow truck when I read the post about the floor mat holding the accelerator down. I just washed the truck including the floor mats and put them back in. As soon as I read this, I went out and checked sure enough the floor mat was holding the accelerator down, which caused the truck to not start. You guys just save me a ton of trouble and thank you.
WalleyeMikeIII
Experience is a powerful teacher. I won’t do this again!
HeavyHoe03
