2021 suburban check engine map sensor
Sobieski79
Hey everyone
So 2021 suburban with cold air intake I have check engine light on after checking with scanner it’s showing that map sensor is faulty code 0106 and 0108
I just replace map sensor light when off and its on again after driving for about 80 miles
Did anyone experience same problems after installing cold air intake
StephenPT
St. Helens, OR
Do you have the factory air intake system? If so, I'd reinstall and see if you continue to get the trouble codes.
as already noted above it very well could be the cai if it is not a oem one, these newer vehicles are more sensitive to them than previous generations and getting a tune for it is pretty much not possible yet unless someone has came out with the option recently
AdrienR
