2017 Tahoe LT -left turn signal upper 4 bulbs out?
TahoeFL2017
My left rear turn signal bulbs are not working, the 4 bulbs at the top of the turn signal - anyone know what this would be?
Didn't get damaged, I just find it odd that all 4 upper bulbs would go out at the same time, is this a potential fuse issue?
Is this a easy or hard fix?
Any and all replies appreciated!
STORMIN08
fuse issue i would think would take out all rear or all on the circuit.
more than likely a connection issues in the rear of the light panel. i want to say that the boards in these years are known for failures.
1BADI5
DMV
Yeah there is a class action lawsuit floating around out there about the ****** LED tail lights on the 15-20 Tahoe and Yukon
TahoeFL2017
TahoeFL2017
Any suggestions on what to try for a fix?
Should I pull off the tailight assembly and check connections, or is this a dealership kinda repair, I don't want to waste my weekend if avoidable, lol, any replies appreciated!
TahoeFL2017
TahoeFL2017
Dealer quoted $400 with installation, should I do this?
Just your opinions.....
Tahoe14
Central Fl
Dealer quoted $400> Is this for a new taillight installed. Dealers are always more expensive, should be a youtube on how to change, get the part# and shop Rockauto, Ebay, Amazon and Google search. Good luck.
TahoeFL2017
TahoeFL2017
Rock Auto is $386, so my options are junkyard or dealer, dealer is $300 plus $70 install - not a whole lot of motivation to do it myself , $370 reasons total to try to get a better deal, but doubt it's going to be much less , unless there's a junkyard with a totaled Tahoe, and no tail light damages.
STORMIN08
There are post around about what to soilder to make the fix...should not be hard to do.
TahoeFL2017
TahoeFL2017
Anyone know if the 2017's came with non-LED tailight/turn signal bulbs?
Watched a Youtube video, but it was a guy swapping out bulbs for LED's, so wondering if 2017 , ordered in 2016, may have had regular bulbs?
Bottom half of rear turn signal is fine, top half (4 bulbs are out) so technically legal to drive it, but have an appointment at the dealer on Weds - trying to avoid it , but a chimp has better mechanical skills than me - soldering a circuit board is not in my skill set.
Changing a bulb, yes. lol
Any replies appreciated!
Tahoe14
Central Fl
If you can pull the whole assembly then you could send it out to have it fixed. Probably going to be cheaper than the Dealer. Do a Google search on repairing rear tail light to determine the cost. Should be a youtube on how to pull it, if you are not sure or do not feel comfortable maybe one of your friends with a little bit of mechanical skills could help. Its not real hard to pull.
TahoeFL2017
TahoeFL2017
Actually - after 2 posts, 6+ overly complex You Tube videos, and endlessly searching Google - just got home from the dealer, it WAS just a bulb, not the whole assembly total of $53 bucks including labor.
Appreciate the replies, but sometimes DIY is harder and more expensive than just a 45 minute appointment at a reputable dealer. Home before lunch and not tools or work required.
5 star reveiw for Dick Norris GMC/Buick in Clearwater FL - those guys are straight up no-BS!
Tahoe14
Central Fl
Glad you got it worked out and you had a good Dealer experience with a fair price. That seems to be rare these days. Those tail lights seem to be very problematic and usually a new tail light or the soder repair is needed. We try to help based on the information, experience and what others share with the same or similar issues. We all learn from each other and thank you for posting back the resolution. Maybe this will help someone else.
TahoeFL2017
TahoeFL2017
Fixed ! $53 bucks, just a bulb, apparently, I got lucky. (But the wife is already taking the $$$ and scheduling some expensive hair tint and some extensions, so the same cost, the wives know how to work us....)
kurtibm
Grand Canyon
On an LT Tahoe I believe there are just 3 bulbs in the tail light; brake, turn and reverse.
MonteJ
