2016 Yukon Denali..Bleeding Brakes???
Low07Hoe
I have a 2016 Yukon Denali I bought about 3 weeks ago and I just lowered it and while apart I disassembled the brake calipers and had them powder coated along with all the other suspension parts. Rebuild them after and installed and now I’m having issues bleeding them. I’ve bleed 2 bottles of brake fluid through the system and the pedal is still going to the Floor unless I pump it 3-4 times. Any secrets?
Multnomah Falls
You have answers to your question. Welcome to the forum from Oregon.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
lilb
