2015 Tahoe..Upper Valve Cover Leak
Dale267
I have a nusiance oil leak. The dealer said it was coming from the upper valve cover. They said you have to remove a few things to get to it and quoted $1200. Has anyone else experienced this leak and did you get repaired.
D
Dale267
It is on a 2015 Tahoe
Tiredmechanic23
Not that much to remove. Plastic covers, coils, breather lines to start. Probably have to move push the harness out the way a bit but no biggie. If its pass side the 2 heater lines run over it and may give enough for removal but could also need removed at the heater core connections. Valve covers are pretty easy. How many hours of labor are they quoting?
ivin74
05 NBS Nali
Htown, Texas
Are you talking about the valley pan cover or the valve cover, the price cost seems about right for the valley pan cover R&R. I personally would do the work and save $1200 bucks.
D
Dale267
They called it the upper valve cover. I think it was around 8 hours they quoted.
The service rep seemed embarrassed to quote $1200 and hinted it could be done cheaper but said they needed to remove a lot of items to make sure they could do it right.
Others might not remove everything and try to squeeze the cover out.
Artichoke
