2015 GMC Yukon XL SLT Apple Carplay?
MEA403
Good afternoon all,
Does anyone know if there is a software upgrade or a module upgrade, where I can get apple carplay in my 2015 Yukon XL. I know that it was a option is mid 2016+. I'm trying to keep my dash as stock as possible, but get the benefit of maps that are always updated.
Thanks in advance.
Big Mama
Virginia
Welcome to the forum from Virginia. I don’t think there’s an update. I think it’s hardware related but some of folks with more experience with your rig will chime in. My 14 Sierra didn’t have it and I believe it’s the same hardware. If you replace yours there are lots of options to keep your stock look.
Good afternoon all,
Thanks in advance.
yes, you just have to change out the HMI module, properly programmed of course. as noted already wams can do it for you.
you just have to do your research for how much it will cost you, there are options.
kk1lron
You have to upgrade the radio as well. WAMS can provide them or you can get them on eBay.
I did this with my 2015 Yukon XL in January. Just the other day my center console went blank...dash control of radio only. I am working on figuring out what failed, but it could be the salvage HMI I bought on eBay from Nationwide Auto Salvage. WAMS says that happens often. It was working well for a few months. If I had it to do again I would have bought it all from WAMS.
91RS
GA
I'm sure all of theirs come from salvage yards also.
Depends on if you have the larger screen already or not, if you have the small screen then yes and it's technically not a radio it's just a display
kk1lron
I do mean the radio receiver. It is inside the console under the screen.
buckwild27
EMT/First Responder Firefighter
Ohio
You need to change the radio module and the hmi module out with ones from a newer vehicle also your gauge cluster needs reprogrammed for the steering wheel buttons to function. Or you can upgrade to the denali cluster. It's easier to just get everything from whiteautoandmedia.com they can program new modules and ship them out to you.
egdufrn
Good afternoon all,
Thanks in advancheck with the dealer. The option doesn't show up until you load the app on you phone and plug in a USB cable to the truck... It does not work without the cable, at least not for Android. Hope that helps.
buckwild27
Ohio
might be the case for the 2015, the wifes 2016 has it already and only needed the HMI & gps antenna for nav upgrade on my 2018
Yes they didn't come out with it till 2016. So for the 14-15 to have Android auto/Carplay everything needs changed.
Hodmjstone
