2015 6.2 liter Yukon xl denali clicking on exceleration only.
dbedave
I have 200k on my 2015 Yukon xl denali. It has a 6.2 liter with 8 psd transmission. At 175k I had all the lifters replaced due to a collapsed lifter. About a 2 month ago noticed a clicking on exceleration, but would go away after a few seconds. Then started to turn up more and more. Only hear it when exceleration. If the truck is in park it will not do it!! I have taken it to mechanics and they can't figure out what's going on. Any advice would be great, thanks David Murr
B-train
Does the sound go away as speed increases, gear change, rpm change. Can you drive a certain speed and keep doing it? Where does the noise sound like it's originating from? Is it a noise that follows engine rpm or vehicle speed?
yukon06
following this.
I have a ticking sound upon acceleration as well but not all the time it comes and goes.
D
dbedave
THarber
Kinda sounds like maybe spark knock. Run a tank of premium and see if it goes away or not.
D
dbedave
The ticking is definitely related to engine speed. So for example, I'm driving 60 miles an hour with no ticking, slow down and take a right hand turn onto the on-ramp and accelerate. As soon as I start accelerating the ticking starts all the way through the gears until speed normalizes. Then I can be driving 80 miles an hour, and then all the sudden it'll slowly start to tick. As soon as I hit the break the ticking will stop. I've even tried putting the vehicle into neutral, when the ticking was going on, and then revving the engine. The ticking will go away as soon as I put it into neutral, and when I rev it, it will not come back. Sitting in the driveway in park or neutral I can rev it as much as I want and it will never tick.
D
dbedave
I have been running premium for two tanks and it did nothing. Even tried running no ethanol gas.
D
dbedave
Agree with @THarber that it sounds like spark knock. Less likely is a loose, broken, or missing exhaust manifold bolt.
The frustrating thing is only time you can hear it is when you're driving. If you're just outside the vehicle and have somebody rev the engine it will never tick. So it's hard to see where the ticking is coming from.
Fless
Moderator
People's Republic of Colorado
Will it do it if you power brake it while it's sitting there? Load down the drivetrain?
Fless
Moderator
Probably need to have a graphing scanner running while it happens then to confirm or disprove knock retard. Maybe just to rule it out.
D
dbedave
What type of scanner do I need? All I have is a $19 code reader
D
dbedave
For some reason it won't allow me to attach the link. Yes it does happen under hard acceleration sometimes. It seems like when I downshift to pass it does not do it. But when I'm going slow and then accelerate hard it does it.
yukon06
im looking at spark knock....seems worth a try to clear it up im reading is a higher octane gas or
  1. Treating your engine with a carbon cleaner or a fuel system additive, can usually clears this up.
Conedaddy
