2012 Suburban..Heated steering wheel problem
Sweet Pete
Hello All,
I just bought a 2012 Suburban LTZ. The heated steering wheel isn’t working correctly. The button wouldn’t light when pressed and no heat on the wheel.
I checked fuse #48 and it’s good. Next I found the 7.5amp inline fuse under the dash, which was good too. After that I turned the key to accessory and the heated steering wheel functioned properly. However, when I turned the engine on the heated steering wheel stopped working. Even if I tried it with engine off the button again it still wouldn’t work.
I pulled the 7.5 amp fuse and reinserted it and once again the heated steering wheel functioned until I turned the engine on.
Does anyone have any suggestions on how to fix this? Thanks.
Hello All,
Welcome Pete, I'll take a look through the manual tomorrow and get back to you. Did it originally come with the heated wheel or did someone add it? Don't know the RPO off-hand but someone might.
Sweet Pete
Sweet Pete
Thanks for your help. I assume the headed steering wheel was factory installed, but I suppose I don’t know for sure.
St. Louis
The RPO codes concerning heated steering wheels are:
NR7 - leather wrapped
NSH - wood
N31
N57 - leather with adaptive cruise
UVD - switch steerinv wheel, heated
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Sweet Pete
Sweet Pete
Thanks for the RPO codes. My truck has a NP5 instead, which best I know is “leather wrapped.” That means the heated steering wheel was added by a previous owner?
wjburken
Eastern Iowa
On my 2013 Yukon XL Denali, N30 is leather wrapped steering wheel and UVD is Heated Steering Wheel.
The LTZs had an all leather heated wheel whereas the Denali and Escalade had wheels with wood trim, different RPO codes. I think you might have something like KA9. Anyhow, if you want the wiring diagram, send me an email.
St. Louis
I don't have any of those RPO codes I listed above on my 2012 Denali. I do have KA9 and N30, but no UVD.
I did miss KA9 on my original list because it's listed as "heater steering wheel" and not "heated" on the RPO list sheet I searched... Lol
N30 is Sterring Wheel Deluxe
2001 Yukon SLT
JohnnyMDenali
Hi, I have the exact same symptoms on my '13 Denali. Anyone have any input? I looked over the schematic and the only thing I've deduced that its an internal issue with the heated steering wheel module? Appreciate any input so I can fix this! Thanks
Sweet Pete
Sweet Pete
I’ve arrived at the same conclusion, but haven’t had an opportunity to troubleshoot it beyond looking at the schematic. If I do, I’ll provide an updated, until then I was hoping someone else had run into this problem and could provide their solution.
Charlie Davidson
Dickson, TN
Just wanted to chime in, 2012 Tahoe LTZ here and I'm having the same exact issue as of a couple months ago. Heated wheel works ..... until you start the engine.
I went as far as taking the wheel off, disassembling the entire wheel to get to the control module in the back left side (behind the plastic cover) and opened up the module. Everything looked good, no bad solder joints or obvious signs of damage/blown components. I am at a loss!
I just bought a used Escalade heated steering wheel for practically nothing. I'm gonna tinker with this thing and see if the Escalade wheel works.
I tried to just purchase a whole new steering wheel about a month ago (my P/N is 20998065) and nobody - NOBODY has this wheel available anymore. I called at least 30 different big name dealerships around the US and even a few large OEM parts houses and came up with nothing. Even the guys I spoke with were baffled that nobody, anywhere had these wheels anymore. Plenty of them in other colors though!
Anyway, I'll see what I can figure out and post updates.
Charlie Davidson
Dickson, TN
You know, I just thought of something. Have any of you had your battery replaced around the same time this started going on?
I remember after getting a new battery is roughly when this started for me.
biker_il
any success?
have a 2012 yukon xl lt2 that has this problem for 7 years now.
Geotrash
Dave
Richmond, VA
I have seen reports of others having this problem elsewhere and in those cases, a new heated steering wheel module fixed the problem. If you have a Tech 2, you should be able to see live data on what's happening with the module. It does depend on certain resistance values, so it's also possible that the clockspring or wiring is creating resistance outside the acceptable parameters, but in any case, here is the module:
petethepug
Michael
SoCal
That’s good you got it to work 2x. I would be willing to bet that if it’s owner installed it’s not happy with the source that’s powering it or there’s a compatibility issue with the switch pack added to the wheel for on/off.
You’re so close.
Martin Evans
Hello All,
Hello, I'm having the same problem with my 07 Yukon Denali XL. Heated steering wheel didn't work and cruise control worked intermittently. Installed new clock spring, still have same problem. Found this forum after having already installed the clock spring and checked the heated steering wheel with key on. It works with the key on but not running. Bad switch maybe? Thanks!
scottd
