2011 Yukon Denali not starting.
HaloDark
Hi everyone. My name is Halo. I recently purchased a 2011 GMC Yukon Denali from auction. It was running fine until a couple of days ago I noticed it was taking a little longer to crank the engine before it would start. Then, yesterday at the gas station I parked at the pump and went inside to pay for gas, pumped the gas and when I tried to start it, it just clicked and wouldn't start. I tested the battery and it's fine. I am going to replace all the fuses and relays tomorrow, but I feel like it's probably the starter. Does anyone have any advice for replacing the starter?
j91z28d1
could be starter, but also cables failing is pretty common.
starter is pretty straight forward. 2 bolts under the passenger side. and the wires
Welcome to the Forum from NH.
Pics of the truck, please.
A quick starter test is to have somebody attempt to start the truck, and when you hear the click, smack the starter with a hammer to give it a slight mechanical shock. If it fires up, then it is most likely the starter or its attached (not-replaceable) relay.
"I tested the battery and it's fine." - The only true way to test a battery is to pull it out of the truck, take it to an auto parts/battery store with a bench load tester, and get it load tested. Have you done that? If not, do it, before firing the parts cannon with its associated extra costs.
If the battery load tests as good, then thoroughly check the battery cables to the main fuse, to ground, and to the starter. These cables typically rot from the inside out, so a continuity test should be performed on each cable to ensure that their resistance is very low.
If the main cables check out OK, then check all grounds in the engine bay, including the motor to firewall ground, to ensure that they are clean and tight.
If engine bay grounds are good, then check the ground on the truck's frame, approximately below the driver's feet.
solli5pack
Follow Joseph's advice and above all....Figure out whats wrong with it before replacing anything.
rdezs
Some items I change due to mileage & preventative maintenance....as it's my wife's ride. Over 150,000 miles, new (not rebuilt) AC Delco starter. New cables, replace all relays in box under the hood.
John H Daniel
For electrical mysteries I recommend seeing my post on the engine area fuse box. It gets corroded and relays randomly don't work, affecting starting, lights, etc. Mine is 2011 Yukon Denali. Folks mentioned cables, grounds, etc; didn't find that to be the problem. Tho it never hurts to check that stuff.
You can take it out and apart, clean it in an afternoon.
To check, have someone try starting or whatever while wiggling those big cable bundles.
XLDenali11
Had a similar issue when I first got my Denali. It would drive fine and then all of a sudden it would not start and just give me a click. If I wiggled the main ground cable it would temporarily fix the issue and get me going. Ended up replacing the main ground cable and have not had that issue for almost 3 years now. Here is a link to the one I got.
georgerenner
Had that happen to me was the cable coming loose to the starter. Cables first!
TexasTaz
