2011 Tahoe Z71
Canesfan1978
Walnut Creek
Hey guy's, just looking to get as much advice as possible. I have a 2011 Chevy Tahoe Z71 which I had lowered a while back. Love the work, matter of fact Tony did the work and I love it. Only problem is I'm giving it to my little brother and he lives in Lake Tahoe and I'm not sure how the tires will hold up. I have 22 in rims on 305/40R Copper Zeon tires. Would you recommend spending a grip on cash to find stock parts from Chevy and put it back to stock and get new tires and rims, or are there any other tires that would look good on 22's and still be descent in snow. Any advice is always appreciated.
Canesfan1978
Canesfan1978
Walnut Creek
I'm looking for anything that will look good on a lowered Tahoe, and be good in the snow. He works at Squaw Valley and needs to be able to use the 4x4, not that he can't use it now, but I just don't see those tires providing for much traction. He won't be off roading in it or taking it through knarly snow patches, just everyday driving in snow, rain, stuff like that?
felixgun
Lafayette, LA
Blizzak DM-V1 is by far the best snow tire they make. If where he's at has a LOT of snow then definitely get those for max traction on snow.
Canesfan1978
Canesfan1978
Walnut Creek
What kind of tires do you have on you Avalanche? Not sure the Blizzak would look good with the Elite Rade rims currently on. Looks like I may be shit out of luck.
felixgun
Lafayette, LA
Yea Blizzak's didn't have "the looks" in mind when they were making that tire. Purely engineered the best tire for traction on snow and that's it.
Honestly if he has 4x4 he should be fine as long as he stays in 4x4 when in snow/rain. My escalade is AWD so I put on some Nitto NT420S tires bc it's the sickest tread pattern i've ever seen on a road tire. My avalanche has 33x12.50R22 Toyo Open Country M/T's on a 22x9 with +31 offset rim. Here are some pics:
CYKBC
At tires have better ride and traction in anything but mud than the mt tires. Mt tires look cool at a major mpg cost as they weight nearly 15 pounds more per tire. When comparing to steet tires the differential has got to be pushing 25 to 30 pounds per corner!
It'll knock the wind out of accelration, braking, wear and tear, mpg. Toyo mts are pretty darn quiet though. Ran them on my Lexus SUV. The best mt tires on the market. Just know what you're getting into.
felixgun
Lafayette, LA
I had LTZ 20's + 305/50/20 Nitto Terra Grapplers on my avalanche beforehand and got 14.8 mpg. I've now had the Toyo Open Country MT's for a few months with rep ck375 22's and my mpg is....... still 14.8 -- absolutely 0 change in mpg... just food for thought. I thought i'd lose major mpg's but I didn't.
---------- Post added at 01:08 AM ---------- Previous post was at 01:06 AM ----------
I'll have to look into those, looks nice on your ride. I wonder if those would fit on my 22's?
Thanks bro. They might fit your 22's BUT lowered it'll be rubbing pretty badly. I have a 2.5"/1.5" leveling kit on my avalanche and still had to trim the wheel well liners and take off the factory mud flaps since it was rubbing on those too. Depending on your offset your rims has, it could be better or worse. A positive offset would make it a lot easier for you to fit. My rims have a +31 offset which is a good thing as far as rubbing is concerned.
NORCAL SS
SUV SUSPENSION GURU
spindles in front
rear we can replace the spring
305 45 22s
CYKBC
Likely the diameter of your MTs are larger which may lead to the discrepancy. I moved from the Open Country ATs to the MTs and I could very easily feel the added weight. There's no argument here. It adds weight. At least 20lbs of unsprung weight per corner. Heavy beasts.
MTs are a good aesthetic choice. Practical? Not so much.
NORCAL SS
SUV SUSPENSION GURU
Or you can do a 285 50 20. Main thing we need to get stock spindles back on your truck.
Seeing he will go in snow id get rid of your chome wheels since snow will eat em up. Tbss gloss bkack 22x9 with 285 50 22 would work ouy perfect.
Rear belltech 2 inch soring and ill keep the one inch spacer in will gice the truck a mre even look and ride good.
felixgun
Lafayette, LA
I do agree that it does add weight. There is also added weight going from LTZ 20's to rep ck375 22's. Which is why I find it odd that I in fact -didn't- lose any MPG's... 14.8 before and 14.8 after :confused:
moto
