2011 Border Patrol SSV/What tire size?
opfor2
Riverside County, CA
Presently, my 2011 Border Patrol SSV has lt285/70R17 tires and the OEM stock tire should be lt265/70R17. What are the pro's and cons of keeping the bigger tires vs the stock size? BTW I just got this vehicle and I really haven't had a chance to drive it much.
mikez71
Should feel quicker with smaller tires. I didn't notice going to stock sierra 265/65-17 from stock 18's..
Smaller is usually more of a road tire, might get a higher speed rating..
I'm planning to go 285/70-17 like you have..
Little more ground clearance with the bigger tires.. little wider tread you give little more traction. Little tougher on bearings?
Marky Dissod
Presently, my 2011 Border Patrol SSV has LT285/70R17 tires.
OEM stock tire should be LT265/70R17.
Depends on how & why you drive it.
If you offroad it often enough, seriously consider LT285/70R17, 'ell, maybe even bigger.
If you don't offroad that much, 265/70R17 is one of the most popular / common tire sizes in the country, so the selection of types of tires to choose from will be far greater and (mostly) less costly than more niche tire sizes.
Tupapi
