2010 Tahoe LT Noob (Bose or not)
strongz
Houston, TX
I just bought a 2010 Tahoe LT and the "high" speakers next to the windshield say Bose on them, but I don't see Bose on the head unit. The truck does not have NAV or a screen, so it looks pretty basic to me. Is it possible to tell if I have the Bose system or not?
Also, if I swap out the head unit for a Pioneer DVD in-dash with back-up camera (no NAV), will it still work with the factory bluetooth and the rear audio controls?
Thanks guys, and I apologize if there is a similar thread out there for this.
ChrisAU
Birmingham, AL
If the tweeters on the pillars say Bose, then you have Bose.
As far as the interface questions, I'm not sure exactly what you need, but I think the Pac OS-4 should take care of all that.
felixgun
Lafayette, LA
I had your exact set up and switched to the pioneer nav DD. Like Chris said, it says Bose so you have Bose. Mine came with the GM 6 disc CD changer that I sold on Ebay. The thing that's Bose are the door speakers/pillar tweeters/6" sub under the center console, and a pre-amp that all of that is hooked up to. I have an aftermarket screen/amp/sub and still have my bose pre-amp/6" sub under center console/factory door speakers in and with the pioneer DD it made the Bose speakers THAT much better! Now I have a 6" in the front (stock bose) and a 10" downfiring in the rear in between the captains chars (Kicker L7 10) for a little equality of bass in the car. Don't know about the factory bluetooth/rear audio controls though.
S
strongz
Houston, TX
Thanks Felix. You're truck looks awesome! I'm really considering the Pioneer in-dash DVD, but I want to make sure I don't lose any functionality.
felixgun
Lafayette, LA
Thanks man appreciate it! What functionality are you worried about losing? The only thing I wish was better was the bluetooth phone calls (other person cannot hear me when I am using it). Other then that Pioneer takes the cake. The Z110BT I have (now the Z130BT this year) is 7" where stock nav is 6.5" screen. I can play DVD/SD/USB/iPod/XM(add-on)/HD Radio(add-on), connect to Bluetooth audio/phone calls, and also have the ream cam. I also have two adapters to make it all "work".
PAC-OS 4:
Retains On Star
Retains factory Bluetooth in 2009 and newer
Retains factory back-up camera
Retains factory installed XM radio (RSE controls required)
Works on amplified and non amplified audio systems including premium BOSE
PAC SWI-PS:
Allows you to control select Pioneer and Sony stereos with your factory steering wheel controls
S
strongz
Houston, TX
PAC-OS 4:
Retains On Star
PAC SWI-PS:
Felix - I am concerned I will lose the rear audio control feature, but your post above about how the other person on the other end of the phone can't hear you over bluetooth is a big deal for me. What's the point of having bluetooth phone calls if the other person can't hear you? I get that with Bluetooth you can use your iPhone or whatever for the radio functions (music, Pandora, etc), but are you saying that the phone part doesn't work well?
felixgun
Lafayette, LA
Yea that's what I'm saying... and exactly,,, what's the point? I'm not too happy about it either since i've invested $1400+ for this nav/bluetooth system and people can barely hear me when I try to use it. It's not my iPhone 4 though i'm pretty sure the underlying issue is the ****** microphone they give you. On avic411.com this topic has been discussed and people have gone out of their way to purchase a 3rd party mic to pair up with this to solve the issue. To make phone calls is a breeze from the screen though, I still use it and basically wait for whoever i'm talking to to start bitching about not being able to hear me before finally switching.
S
strongz
Houston, TX
Felix, I know you don't have the 2010 Tahoe, but in the comments you posted about the PAC-OS4, it says it retains factory bluetooth. Sounds like I wouldn't have to use the aftermarket mic afterall, but could just use the factory stuff. Not sure how that works, but if it does I like it!
felixgun
Lafayette, LA
Yea mine is an 08 so it didn't come with factory BT but yea that's what it claims so it must work... I used the aftermarket bluetooth on the pioneer nav DD and wanted the PAC OS 4 to retain my Bose stuff
S
strongz
Houston, TX
Felix - now that you've had the OEM Navi and the Pioneer in the past, which do you prefer in terms of looks, usability, bluetooth features, etc?
felixgun
Lafayette, LA
First off the OEM navi doesn't have bluetooth. The VCIM from an 09+ bluetooth enabled vehicle can be put in the 07-08's to get it though. Even aside from the Bluetooth, the Pioneer aftermarket AVIC flagship nav screen ***** on the factory nav screen. It's three times as fast navigating and looks way better. You can also get a ~$50 iDevice 30 pin dock connector cable for the pioneer screens versus having none and having to get a ****** GMX550 LockPick for the factory nav. The screen is also 7" versus 6.5" factory one which is actually a huge difference now that i've had both. One con that I found in having the pioneer is the bluetooth phone feature (only phone-- bluetooth audio is spot on). When I would make calls the person on the other line could never understand me with the pioneer supplied aftermarket mic. If I could do it again though, i'd get neither and go with the flagship Kenwood DNX9980HD with garmin nav built in...
dizhai
