having 4 plus still in can slow down how faster the starter and spin over. and since you're doing a cranking compression test. a small amount of speed can cause a big difference in psi.
that's why he asked.
but yes, just replacing the injector doesn't mean its getting the signal form the ecm to open. also where did you get the injector? hang on to the old one, as it's probably best to put in back in after you solve the miss. these cheap Amazon/ebay no name injectors have a totally different opening time compared to oem. very expensive aftermarket injectors come with that data which will then be programed into the ecm to compensate using something like hptuners software. short if that, it'***** or miss.
